ezerini avatar image
ezerini asked
Prevent BMV from switching off when battery shuts off
Hello, I have a LifePo4 battery with BMS and I’m monitoring it with the BMV702.
Every time the battery runs off and shuts down, I lose data on the BMV so the SOC is always needing to be reset by a full charge and I don’t see the ‘last discharge’ data.
I’m planning to use the relay to switch off appliances before it gets to a full discharge, but is there another way to maintain power to the Victron, perhaps with the starter battery, or another independent source to keep the BMV on?!
I’ve got a 24v leisure battery.
BMV Battery Monitor
snoobler avatar image
snoobler answered ·
Stop running the battery to 0%.
Continue with your plan to provide a means of protecting the battery by removing loads.
IMHO, the data is meaningless. If the battery is discharged to 0%, the "last discharge data" is "too much," regardless of the actual value.
When you know the battery is recovering from 0%, you can manually set the SoC to 0% thus negating the need for a full charge.
