Hello every one, I searched for quite some time on here and other forums but I can't find the answer any where. First question is, Is my set up correct or is something undersized? And second what fuses do I need for the Shunt and the Distributor?
Are you bus bar connecting your batteries or looping them (Parellel)? Possibly use a lynx power in there instead.
I am assuming you are using the 24/3000/120v inverter. You need AWG 1/0 if your run to battery is less than 5m return for DC connections. See manual here.
Yes that is correct I want to use the Multiplus-II 24/3000/120 inverter/Charger. I will 1/0 awg wire from the distributer to the Inverter.
Also what size MEGA Fuse should I use in the Lynx Distributer and CNN fuse in the Lynx Shunt? 500Amps MEGA and 750Amps CNN?
I appreciate your help!
Sorry your diagram shows 4/0 for the cable from lynx to inverter.
The manual linked in my previous reply gives recommended fuse size for the inverter feed at 300A for the 24v/3000.
Size fuses for the cable sizes they are feeding.
The mppt manual also has fuse recommendations.
Panels show maximum fusing rate at 15A on the specs you posted. So a 20A breaker there should be fine.
25 People are following this question.
