I had the #38 and #39 error. it shows voltage peaked at 16 volts, ive followed the procedure to reset. but it still only shows 1w of solar coming in, even though it shows 78 volts on the pv side. any suggestions? I leave on a trip in 2 days.
Have you made sure the battery voltage is set correctly in app?
Maybe post a picture of settings
https://www.victronenergy.com/live/mppt-error-codes#err_38_err_39_-_pv_input_shutdown
Might help if you checked the multiplus actuals and settings.
Have you been through the recovery processes @Alexandra linked to?
65 People are following this question.
