eyub avatar image
eyub asked
DC ripple with quattro and BYD
hello guys
we are facing a weird situation in one of our system since we made the installation till now.
the system is composed of ( 16 kwh LVS BYD + 15 kva quattro + 32 X 400 wp trina solar panel connect to 3 250/100 mppt as 12 pvs /1 mppt)
since the first day we are phasing a dc ripple issue it always happen in the after noon between 11 am to 1 pm the system
we have installed many systems like this combination and they are working perfectly
the byd and the ve configure is same as the Victron and BYD recommendation the type of the cable used are 70 mm and the length is less then 1.2 meter whatsapp-image-2022-07-20-at-105736-am.jpegwhatsapp-image-2022-07-20-at-110032-am.jpeg
Alexandra avatar image
Alexandra answered ·
@eyub
15kVa Quattro uses 2x 95mm² cable for negative and 2x 95mm² for positive. I would start with changing that.
See the quattro printed manual on page 9.
The DC ripple can either be heat (high resistance connections) or the battery voltage or some cell voltages going too high. The only way to determine which is to see more data.
