river avatar image
river asked
250/100 MPPT pv strings
I have an MPPT 250/100 mc4 and 48v battery bank. I have 8 x 325 watt 12v panels. Can I have just one string of 8 in series or should I have two strings of four, each connected independently to a positive and negative plug on the MPPT. In the 2 string option, does this make the array a series parallel connection as the plugs are bussed together inside? Would I need to put breakers on the two strings?
MPPT Controllers
klim8skeptic avatar image
klim8skeptic answered ·
You should probably use the Victron online MPPT calculator.
parallel connection .... Would I need to put breakers on the two strings?
Without panel specs, I would guess that 2 strings paralleled would be over the MC4 connector limit of 30a.
7 comments
river avatar image river commented ·
Thanks. But would the 8 in series be the correct option?
klim8skeptic avatar image klim8skeptic ♦ river commented ·
Need_panel_specs...
Or a data sheet, or even a web link..
river avatar image river klim8skeptic ♦ commented ·
Below is all the info I have on the panels
325 watt panel
open circuit voltage 21.6v,
max power tolerance +- 3%
max power voltage 18v
max system voltage 1000v
cell tech, mono
18 amps
operating temp min -40 c
operating temp max 85 c
You are all good for a single string of 8 panels.
Thanks. I owe you a beer
Thanks again for your help. One more question please, if you don't mind. The MPPT 250/100mc4 data sheet says max pv short circuit 70 amps (max 30 amps per mc4 connecter). Does that mean I can have 2 or 3 20amp strings connected to the controller provided the voltage is not higher than 250V?
Correct.
Bad things happen if you exceed the mppt's input ratings.
