Image Caption
Im having multiple problems with this installation.
330w monocrystaline panel
100/20 mppt
12/250 inverter
2x Bluetooth dongles
3x 12v 110ah carbon gel batteries.
To power 39w diaphragm air pump & 45w pond pump.
Bluetooth is showing 2 MPPT's There's only one in installation with a 12/250 inverter.
PV Voltage reads 12.39 at terminals but reads 36v when disconnected from mppt & directly to multimeter.
Batteries read 12.57 from MPPT battery terminal.
I understand batteries won't charge unless pv Voltage is more than batteries but I can't understand the drop once connected to MPPT.
Please help
Thanks in advance.
