What is the response time for the Multiplus II to disconnect grid feed-in when there are non desirable grid conditions (over/under frequency or over/under voltage). 20ms?
Thanks for your help.
I haven't come across any declarations relating to response times in the face of grid instability, there are likely two reasons why I haven't found this information.
1. It varies based on grid code requirements, so might be country dependent and as such there isn't a one size fits all answer.
2. The multiplus-2 is primarily meant to be used as a grid-tie Energy Storage System and isn't meant to support unstable grids. Off-grid inverters and gen sets are meant for this scenario.
The only other piece of information I have come across that relates to the measurement of the multiplus-2's response to failure scenarios relates to the loss of communication. Specifically in regards to G100:
https://midsummerwholesale.co.uk/pdfs/victron-g100-declaration-multi.pdf
I live in a stable grid country, however am required by local laws to provide these metrics to the grid operator if I intend to feed-in.
I'll keep searching, as the disconnect times must be for the specific model installed (Multiplus II 48-5000-70).
Thanks @sharpener, @Crispin.
This is useful to know.
I've got a Victron team member digging me out the table of compliance trip times for my region. I'll post them here for closure once they are supplied.
55 People are following this question.
