glenn-west avatar image
glenn-west asked
2 MultiPlus 2 230v into autotransformer, setting up for master unit to carry load up to set percentage and then slave make output
I am researching and and really like option on another unit, not mention here, and it allows in multiple units to assign master to carry load to a set point and then slave come on at that point. Basically slave/s sleep until load demands needed. Can MulitPlus be set up this way?
setup
Mike Dorsett avatar image
Mike Dorsett answered ·
Multiplus inverters in parallel usually share the load. This is not usually a problem. The difference in inverter efficiency would be too small to notice, unless you spend a lot of time on really light loads. AES does help save power in this situation. If you have one really big load that is only occasionally used, it might be worth putting this on it's own system.
glenn-west answered ·
2 5k would be 36 watts.
