bergyla avatar image
bergyla asked
3 * Quattro II in parallel with second Source (1 Phase only) supported ???
Is it possible to build a 3 Phase grid with Quattro II working on a 3 Phase Shore Grid.On the secondary AC-IN a Generator w. 1 Phase should be used as Emergency Supply and Batterie-Loader.
Is this supported ?
And if upper scenario is supported, might a MIX of Quattro II and Multiplus II systems possible (As far as I know Quattro II and Multiplus II are sharing a very similar hardware basis and the combination of 1 * Quattro II (for allowing secondary 1 Phase Input) and 2 * Multiplus II might make sense at all ?!?
