ope01 avatar image
ope01 asked
Miltuplus II - charging from MPPT no to ac loads
Hi
I am newbee in Victron, have Multiplus II-GX. I have one question, system is set to ESS with little feed-in and SOC for battery was set to 20%, i have small problem in the morning where i have some power from MPPT but its used for charging the battery not to use it for AC loads. AC loads are fed from grid (for money). How can I set system to use MPPT and battery to fed the AC back again? It worked at night (using battery not grid) until SOC drops down to 21%.
Multiplus-II
lifeingalicia avatar image
lifeingalicia answered ·
Set a scheduled charge e.g. 7 - 9 with SOC 20.
Scheduled charge will use AC/PV up to the desired SOC then charging will stop but NO charging & discharging of battery till end of schedule.
Thus any PV is used for AC or fed back.
