Hello. I installed a three way rotary switch to remotely control my multiplus. If I turn the switch one way it puts it in charge only mode and the other way it puts it in inverter mode. Center position is off. Great! Just as I want! Now… the rotary switch also has a ring led light function that I’d love to glow red when the switch is in either on position. this seemed simple enough but it seems this is not your ordinary 12v circuit and isn’t working. I’m not sure the current going thrumthis switch is enough to power my 12v led. Anyone figure this out? Is there another way to use one of the aux ports on configurable relay to send 12v current thru some wires based on whether the multiplus is in charge only or inverter?
