Running ess. Problem I have is the multi plus will not switch back to mains when mains return and stays battery. I have to switch off main breaker and back on then only it will switch. Voltage is not below values set on inverter.
Hi Ruan; you posted this in Mods; is there anything special with your setup so that it belongs here? Or shall I move it to the normal place for questions?
5 People are following this question.
