gsking avatar image
gsking asked
Mppt 75/15 better at 12v than 24v?
I hooked up my controller to my panels in series thinking it would work better. But each panel produces 115w at 17V… in series I don’t get above 170w but the voltage jumps to 40v
Is the voltage converter unable to trade that excess voltage for current?
In parallel I would exceed 15a, but it states that is an output limit on each output (load and battery). Can I put in up to 20a from the two panels in parallel?
Edit: I found most of the issue. I can only get 15a total output, half of which goes to the refrigerator. The other half is limited by peak voltage. The rest goes to waste. So 350w of panels will be overkill.
Now I just need to learn how to force it to go into bulk charging instead of float.
Thanks
MPPT Controllers
kevgermany avatar image
kevgermany answered ·
Not quite sure what you're saying/asking.
MPPT will convert input voltage and current into whatever fits the battery settings. Series/parallel connections of panels are usually concerned with keeping input voltage within input limits of the controler and making sure you have sufficient voltage to initiate charging.
If you're only getting 170W there are a few causes:
Too little sun/panel shading
Resistance due to poor cabling/connections
Batteries too full to accept full charge
Wrong battery settings.
gsking avatar image gsking commented ·
I figured it out. Yes…my battery connection is fairly high resistance…so it’ll drop from 14.2 to battery voltage of 13.5 at 6 amps or so…providing 80w to the battery. The other 80w are going to the load.
I was able to turn up the voltage to14.8 to get the full outlet to the battery. Then I discovered that the 15a rating is total…it’ll share that output between load and battery for a total output power of only 225w.
Too bad the 75/30 doesn’t have a dedicated load output. I like that feature.
Alexandra avatar image
Alexandra answered ·
@Gsking
Basically power is volts multiplied by amps. W=V*A
15A x 12Volt (battery) is 180W
15A x 24V (battery) is 360W.
So yes if you are using a 24v battery you will be able to harvest more power with the 75\15 mppt.
If you are seeing less watts at 12v either you have less than 1000w/m² irradiation or your panels are above 25°C which is where they are rated.
No you cannot put more than 15A on the PV side. It will exceed the short circuit rating. See the tech specs
Alistair Warburton avatar image
Alistair Warburton answered ·
You need to look at VA, Volts X Amps, to get a handle on what is going on.
There could be many isues, and possibly none. The MPPT algorythan essentally varies amperage, by presenting different average loads, and tracks at what voltage and current the best power ia being achieved.
That 'point' will change significantly with the level of irradition and will be very different in full sun as opposed to defused light, cloud,mist and the like. It is also heavily influenced by the type and construction of the panels.
The silly number of variables is exactly why MPPT is not trying to be clever and predict the best voltage but is searching for it by making small changes and obsrving the results.
If your outpit is low, subjectivly, then something may be wrong but you should eliminate the simple stuff first... Connections, dirt, bad allignment, shading... and probably sveral more.
To do a reasonable comparison of the installation performance you need data from several periods that are 'broardly, the same, sun wise, before you could conclude that the MPPT is at fault.
Time and data will get you where ou need to be. I am not saying you dont have an issue, just that without dood data ou are unlikly to find it unless it is a simple obvious fault... Which I expect you have already checked for.
Lastly... If you are using a DC clamp to check current, make sure it will work at the switching frequency of he charge controller, many cant, or use data from the carage controller. The absplute accuracy isnt that importent just the consistency.
If you collect more data you will get better answers here... I am not in any critisizing, just ststing facts. When you have an issue, potential or real, data paints a picture and gets answers. without it all yu will get is guesses and generic advice. You clearly have a handle on the basics but you are probably looking for a nuanced issue.
I work in controls and systems intigration... After decades, I still think a day I dont learn something is a missed opertunity.
Info/Data is your friend, and likely your bigrest challange, when trying to pin down an odd behaviour.
