marko1963 avatar image
marko1963 asked
Multiplus 24/5000/120 keeps cycling on low battery
On overcast days my solar panels cannot charge victron batteries to 100%.. I use them until low battery warning light flashes and I then turn on AC mains power to try to charge the batteries, sometimes as low as 20vdc. It’s a 24vdc system.. the fan does not come on, and the unit cycles on and off every minute or so.. I thought the unit can charge at 120 amps ? It goes into BULK charge for a minute or so and then low battery and overload leds illuminate, and then shuts down for 20 seconds and reboots and does the whole pattern again..
Multiplus-II
@Marko1963 moved to the normal Q&A.
Please give us some more information about your system.
marekp avatar image marekp commented ·
@Marko1963
You are killing your battery by discharging down to 20V.
I does not matter whether it is LFP or LA battery.
