the multi is always reading voltage about 100mV to low also in no load conditions.
After disconnecting the multi for a few minutes the voltage reading is ok, but it’s getting worse after some time.
BMV 712 and BMS and multimeter is measuring the same voltage, only the multi is reads wrong voltage.
The absorption and float voltage is getting also about 100mV higher as programmed voltage.
