VAN THUAN avatar image
VAN THUAN asked
BMV700 connected to NMEA2000 Network / Raymarine i70 can't scan the network
Hello
I have bought the VE-Direct Cable (ASS030520310 ) to connect a BMV700 to the NMEA2000-SeatalkNG network of the boat
I can display the Voltage, Ampères,and SOC on each display (Raymarine Axiom and i70, B&G Triton), this is OK.
But since, the Raymarine i70 can't scan the network anymore to define data sources. So I can't choose the RS150 antenna as speed (SOG) source, and the i70 displays "---" as speed.
If I disconnect the VE-Direct cable, the i70 works fine again.
The i70's firmware is updated. The version of the VE-Direct cable is 1.00. Is there a newer version ?
Best regards.
FX
BMV Battery Monitor
