boatelectronics avatar image
boatelectronics asked
Isolation Transformer, internally fused against overload?
Hi, is the current line of isolation transformers internally fused/protected against overload?
About to install a 2000W isolation transformer. Is there an internal fuse/protection? From the datasheet: "Input circuit breaker: yes". Meanwhile no information is provided in the manual about an input circuit braker, only the soft start.
Should there be an RDC/automatic fuse before and/or after the isolation transformer rated to protect the isolation transformer itself agains overload?
What current rating RDC should be installed to be sure that isolation transformer itself will not be damaged if too much current is drawn? 6A 8A 10A? Will think that the characteristic of the fuse be important here? ( A, B, C etc, C=1,45*Current rating for up to one hour use)
Thank you for any help :)
Isolation Tranformer
