Just curious because from the positive output terminal of the 150/35 charge controller, I'm getting 300-600 ohms, and on the negative terminal I get 0 ohms. Should it be 0?
strange question. What are you trying to measure? if you measure the resistance from one negative terminal of an mppt to the other ( bat to PV) it will be zero, as these are internally connected together.
The PV + to bat + involves all of the internal electronics, so these are not connected together, and measuring the resistance between them is not an indication of the functionality of the unit.
59 People are following this question.
