Hello
Recently had a new Multiplus 3000 inverter installed and overall it's working great. However the voltage it's reading is consistently ~0.5 volts higher than actual. I checked this 3 different ways:
- manually tested batteries using a volt meter
- victron mppt controller
- blue sea dc meter on dc panel
All others show voltage at 0.5 volts lower than the inverter.
Is there some way to calibrate the inverter to correct this?
Thank you
