bugs-bunny avatar image
bugs-bunny asked
Schema small Boat Argofett and Charger with mainbatterie and startbatterie?
Hello, in my boat I will renew the complete electrical system.
I have the following devices that should be installed:
Argo fet 200-2
230V Charger IP65 25A 1xout
1 x 100A main battery
1 x 100A boot battery
I am looking for a schema for the following properties:
- Both batteries should be charged simultaneously via the engine generator
- Both batteries should be charged simultaneously via the 230V charger
- The two batteries should be used individually as starter and main battery, in case of emergency the main battery should also be able to be used for starting.
I have a complete schema as a basis, but I can't see how the starter battery can be charged via the charger.
I don't need a 230V converter or a solar system!
If you could please provide a simple schema, would I be glad?
Greeting André
Schema-BSP-Victron-1.2KVA-12V-MultiPlus-230-Volt-system-example-with-Argo-Fet-and-MPPT.pdf
schematics
