In regards to the Multiplus 2, the AC input current is 50A however the cont. output is only 4000W @25degs (Peak of 9000W)
Does that output wattage only relate to the inverter side of things? Ie what it can charge / draw from the batteries?
So if the generator is operating it can technically output 50A of power to the essential loads? Or only to non essential?
Or is the 4000W the absolute total continuous power the loads can draw?
