George avatar image
George asked
Using Victron Power In with Pylontech batteries.
Hi everyone
I have a Deye 12kw inverter that uses 10x Pylontech 3000C batteries and is connected with a 250A fused disconnect. Because of the limitations of the Pylontech battery cables I want to double my charge rate to 200A. Can I use the Victron Power In as a busbar without fuses using the fused disconnect that I already have or is it better to remove the fused disconnect and modify the Power In to take fuses or buy something like the Lynx Distributor?
Thanks
busbar
