chrisj1952 avatar image
chrisj1952 asked
Why does my Blue Smart charger always interrupt the charge cycle?
I've been using my 24V/13A Blue Smart charger for a few months. It (almost) always interrupts the charge cycle, without my intervention, as shown in the screenshots I've attached . I am using a custom setup to charge my LiFEPO4 batteries, but this issue also occured when I was using the built-in Li-on settings.
charger
kevgermany avatar image
kevgermany answered ·
First guess is that the BMS cuts the charge. What are the charger settings and what does the charger maker suggest. Could also be that the connections are disturbed.
chrisj1952 answered ·
I assume BMS = the Battery Management System in the battery. Possibly, I will check with the manufacturer.
Here are my settings (2 screenshots, 2nd is attached), note float disabled was recommended by battery OEM
Chargers.
