Henk avatar image
Henk asked
Ignore AC input VS function
I am trying to use the Ignore AC input Virtual Switch function.
2 Kva Multi Radio Button set to "Ignore AC Input VS".
Setting: >1200W VS = On; <600W = Off
When the load increases to >1200W the multi does not Switch to the grid.
Please advise what methodology can this be used.
The primary function is to only use the grid when the load is higher.
henk@pasma.com.au
Henk avatar image Henk commented ·
Not sure how to send screenshots on this forum, however if you can advise email address I can send a copy of the vsc file or screenshots.
Regards henk@pasma.com.au
boekel avatar image boekel ♦ Henk commented ·
screenshots are very easy, just drag&drop them into the text. But please do crop / resize if needed.
Henk avatar image
Henk answered ·
Screenshots.
boekel avatar image boekel ♦ commented ·
Have you got it working now? or still unexpected results?
I'm not sure how the 'when no 'VS ON' conditions apply' setting behaves together with the other conditions.
boekel avatar image
boekel answered ·
I think you've got it backwards, VS=on means it will ignore AC input
Can you make screenshots of all the VS settings?
Henk avatar image
Henk answered ·
I have the VS inverted "unticked"
Henk avatar image
Henk answered ·
Issue now resolved.
I have turned ON "Weak AC"
Seems the power supply in this area is not only Low Voltage but possibly requires the weak ac function selected.
