jgsi avatar image
jgsi asked
Help with Calcium Battery charge settings
I have a feeling that I am not charging my sealed , new 12v calcium battery correctly.
What battery settings should I use? Using SmartSolar MPPT 100/20 48v using latest firmware
User Defined...
Absorption Voltage...
Float Voltage...
Equalization Voltage...
cheers for any help
MPPT Controllers
kevgermany avatar image
kevgermany answered ·
Each maker has their own recommendations. Please find the datasheet for your batteries. If it's not clear how this translates to Victron terms we can help.
seb71 avatar image
seb71 answered ·
For sealed lead-acid, normally you disable equalization.
For voltages, if you can't find the battery datasheets (as kevgermany suggested), you could start with the voltages recommended for similar lead-acid batteries.
@jgsi e.g. victron deep cycle
