Battery 120A AMG SLA. 112/12/30A smart charger. Select AMG for batt. On app it state 14.7v but actual charging voltage is 15.26V !! Tried different user def. setting but batt volt on app is not the same as actual volt.
Just a few thoughts here.
The internal resistance is high in the battery so it is most likely not taking a charge anymore. Voltage rise like what you are seeing (then dropping drastically when charge source is removed) usually indicates a dead battery.
T he second is that usually AGM ate charged at C10 so for a 120AH battery that is at max 12A. So the charger you have is too big for the battery.
I am thinking that the mats are dry.
26 People are following this question.
