jwareham avatar image
jwareham asked
Solar charge controller question
Hi all,
I am hoping to wire up a 180 watt solar panel to my Victron MPPT 75/10 solar charger. I understand that this should be wired into the distribution blocks. I was wondering what amp midi fuse I should use for the positive distribution block, I am using 4mm squared cable. The guide I have purchased states 10 amp, but they don't seem to exist!
Thanks in advance,
James
MPPT Controllers
dansonamission avatar image
dansonamission answered ·
Not sure what guide you are looking at by the manual on page 10 indicates between 15A and 20A fuse for the 75/10
https://www.victronenergy.com/upload/documents/Manual_SmartSolar_MPPT_75-10_up_to_100-20/MPPT_solar_charger_manual-en.pdf
klim8skeptic avatar image
klim8skeptic answered ·
Unfortunately you can not find a 10a midi fuse.
You could use 6mm cable and a 30a midi fuse to protect the cable between the battery and mppt.
30a midi fuse.
test.
cairnsbakeryinfo avatar image cairnsbakeryinfo commented ·
test.
