Kevin Windrem avatar image
Kevin Windrem asked
Temperature alarms should not need relay assignment
Currently, the alarm for a temperature sensor is not available unless the condition is assigned to a relay. I would like the alarm conditions to be available even if a relay is not assigned to temperature.
What good is an alarm if it is not assigned to a relay? Answer: the alarm status can be displayed where the actual temperature is shown (like in GuiMods mobile overview and flow overviews). A notification could also be generated but that is currently not happening.
Also the location of the alarm settings is a bit odd as it's in the relay configuration page, not in the temperature sensor setup itself.
feature requestTemperature Alarm
The feature requests topic tag can help Victron R&D find feature suggestions for products.
There are many factors that go into the Victron product roadmap, and feedback from end-users can help.
