palu3492 avatar image
palu3492 asked
Will BlueSolar charge when the battery is zero?
Will the BlueSolar MPPT 75/10 charge a battery with a battery voltage of zero? We are diagnosing an issue with our batteries where the internal BMS is cutting off the power output for an unknown reason. We are working with the battery manufacturer to figure out why. When I throw the battery on a charger, it comes to life and will read a normal voltage like 11-12V. So I'm wondering if the BlueSolar isn't attempting to charge the battery when the battery is in this state? Possibly the BlueSolar sees 0 volts and thinks no battery is connected?
MPPT Controllers
