chrisf1 avatar image
chrisf1 asked
Skylla IP44 not charging
Hello-
I installed a Skylla IP44 12/60A charger (three outputs) on my old boat. The new owner called me to say the charger was not working as the charger was not putting out any charge.
Cycling the power to the charger did not change the situation.
I installed the charger and a carbon GX two years ago, updated the firmware to v. 1.10, and never had to look at it again.
I asked him to observe the LCD display as the charger was power cycled. All segments on the display are shown and then the display goes blank. No errors are shown. Pressing the select button when the display is blank shows “1.10”. Pressing the button cycles through what looks like he battery voltage and charger output for each bank,e.g, “[battery icon] 1 12.7”. The last item displayed is “IC 7.1” or similar. The display will go blank after about 20 seconds.
The only other icon shown on the display when cycling through the display is the “BMS Operation” icon. I do not have a BMS configured or installed in the system.
Pressing the select button for three or more seconds doesn’t help.
Any thoughts? As far as I recall and based on the electrical diagram, there are no fuses between the charger outp and the battery banks.
Thanks for any help!
Chris
Skylla
Allen Roberts avatar image
Allen Roberts answered ·
Did you ever figure this out? I would check the setting for backlight time. It could be the display is just turning off and the unit is actually working.. IC 7.1 means the input current is 7.1 amps which depending on your input voltage is probably reasonable.
chrisf1 answered ·
Hi Allen-
Sorry for the slow reply. The new owner of the boat worked with the vendor's tech support department and determined the unit was faulty. It was replaced under warranty.
Chris
Skylla-IP65 product page (12v, 24v)
Skylla-i product page (24v)
Skylla-TG Charger product page (24v, 48v)
Skylla-TG GMDSS product page (24v)
