Good day
I have a Three phase installation using Quattro 48/8000 .
Generator is connected on AC input 2
I am using the Generator Start/ Stop function to start the generator , based on the SOC of my battery.
I have got the "Do not Run Generator when AC 1 is in use" Enabled
When my Grid Returns and one Phase is missing , the Generator switches off (I assume because of the "Do not run Generator when AC1 is in use " is enabled, but my Invertors does not connect to the Grid because of the Missing Phase . Thus my system drains the battery power to where my battery reaches a Low SOC and disconnects the invertors.
The only work around it is by Disable the "Do Not Run Generator when AC 1 is in use " .
BUT
When Disabling the "DO not run Generator when AC 1 is in use " . The Generator will not switch off until it reaches the SOC setting to switch off , although the Grid is back and all the phases are in check. This is a nuisance by wasting fuel when grid is available and in check
Is there any other work around to Enable the "Do not Run Generator when AC1 is in use " but ONLY when AC 1 is OK in all aspects , before it switches of the Generator. and connecting to the grid .
Regards
Johannes Cronje .
