olivier-hecht avatar image
olivier-hecht asked
Cerbo GX feature request: max generator run time
I'd like to see more control over the generator in terms of run time after it's started automatically - one feature I think would be simple to implement is a Max Run Time per start. There's already a minimum run time. The reason this would be useful is that I use my vehicle engine as the generator and it has a maximum run time of 30 minutes per start, so I need the Cerbo to stop it before that to avoid getting out of sync when the generator (engine) turns off after 30 minutes but the SoC cutoff hasn't been met yet...
Generator
