elvis avatar image
elvis asked
ESS Feed-in Limiting causes MPPT to be erratic. Is it Normal?
Multiplus II 12/3000/120-50 2X-120V
SmartSolar Charger 150/35 (4 100W panels in series)
SmartSolar Charger 100/20 (Single 250W panel)
BMV 712
400Ah LifePO4 Batteries (X2 200AH in parallel)
CerboGX
Battery charging MPPT's are pretty smooth and maxed out.
As soon as the battery is full, Feed-in is active and the MPPT's become erratic.
Is it normal? Maybe the inverter trying to calculate proper sync values?
Here is another example with limiting turned on
Example with limiting turned off
MPPT ControllersESSgrid
elvis avatar image
elvis answered ·
Well, It would seem the issue is related to the Limit Feed-in setting.
I had it set to 700W. This is well above a normal achievable output value. I only set it that high in the hope it might limit a spike that sometimes happens and the battery supplies 6 7 or 8 hundred watts to the grid for several seconds. Typical feed-in during full sun is less than 500W. Even tho this feed-in limit value is rarely seen, the fact that it is "Set" has the weird effect of oscillating / pulsing the feed-in power. If I set it to 1000W its no problem. So My question is...What is the limit value actually a limit of?
I figured it would be the actual value being feed in. But that does not appear to be the case.
Any ideas?
