Hi, I have been battling for a week to find information on how to reset the automatic battery voltage detection on MTTP 75 | 15 .
I have a bank of large individual lead-acid cells which I connected as 24V. The Victron detected this and autoset to 24V charging cycle. However, I now need to connect this a 12V bank and the regulator's "automatic" detection only work once and keeps trying to overcharge my battery.
I have found a MTTP 150 manual which states it can be reset by shorting the "output" and applying an input for several seconds. This does NOT work on MTTP 75 series. ( I'm guessing they mean the battery output , not the load output since this is not specified ).
The same manual tells me this can be set by computer but FAILS to say how this can be done. I'm guessing , again, that this can be done via VE.direct but without a specific command and value setting this is no use.
Automatic voltage recognition can be switched off and a fixed 12/24/36 or 48 V sy stem voltage can be set with a computer or a Color Control panel.
I have a working USB connection via FTDI cable and can see the status output from the regulator. I do not have a smartphone.
Can anyone tell me what command I need to send to the MPPT 75 or where this documentation can be found. I've downloaded everything I can find but have not been able to locate this gem of information.
TIA.
