tator avatar image
tator asked
Voltage Sense Wire Size
I'm on the final hookup of my multiplus 3000 on my boat and have a simple question. The manual calls for a 20awg wire to connect the voltage sense. Will an 18awg work? I'm in Alaska and tinned wire can be hard to find here. I have tinned wire from 4/0 cables to 18awg but nothing finer.
Thanks, Tator
voltage
snoobler avatar image
snoobler answered ·
A specified awg is typically a minimum. You can certainly use larger if you choose. Just make sure appropriate overcurrent protection (fuse/breaker) is installed.
ako avatar image
ako answered ·
Morningstar which is also a quality product recommend sense wire to be between .16 and 24 awg .
