I am wanting to know if there is a way to turn just the inverter only off, but leave the charger on on the RS SmartSolar 48/6000?
It is completely off if you use the on/off switch, even with solar connected.
If you have a GX connected you can switch it to charger only in the device menu.
You can over Bluetooth and its own internal monitoring also switch it on or off and to charger only.
Thanks for that info, I have not seen that option in Victron Connect. Is this local connected only or can this be done through the VRM? Is this option available to change in Remote Console?
You can use the remote console if you have a GX device as well.
25 People are following this question.
