nathanturnock avatar image
nathanturnock asked
How do I wire a 100/30 Smart Solar contoller with Smart Shunt?
Hi All, I have a Smart shunt and 100/30 Smart solar controller which I will be wiring into my camper trailer soon. I will be running when off grid 2x200watt 12v solar panels
I have dual agm batteries wired in parralell.
What's the best way to wire them in...can they be wired so that the battery + on the 100/30 goes to the + on the shunt and the - to the - on the battery or should it not be wired to smat shunt at all
Thanks in advance
wiring diagram
snoobler avatar image
snoobler answered ·
Smartshunt is the only thing connected to the negative battery terminal. All loads and chargers connect to the other end of the shunt.
https://www.victronenergy.com/upload/documents/Datasheet-SmartShunt-EN.pdf
