Hi I using an Multi with an Pylontech. How will i get the energy going to and from the batterie by modbus simular to that what the vrm shows?
unit 100 register 840 - 846
best to download full register list from here
https://www.victronenergy.com/support-and-downloads/technical-information
I looked for the same information and it was not available using the modbusTCP interface.
So instead I use MQTT. I subscribed to the energy fields available on the vebus. They are labelled vebus/275/Energy/InverterToAcIn1 and vebus/275/Energy/AcIn1ToInverter
I'm getting updates coming in but the value does not seem correct.In the whole night (discharge) the reported value only changed by 0.08kWh. While the real number should have been around 4kWh.
I'm not sure what's happening...
29 People are following this question.
