I have a Rpi 3 B+ running OS 2.66. It says it's the latest version. I would like to add Ruvvi tags to monitor fridge and air temp. Do I need to upgrade my Rpi to a 4 or can I run 2.80 or 2.90?
no need to upgrade to a Rpi 4. The Pi 3 B+ will do fine. But you need to update Venus OS firmware, which currently is v2.85. V2.90 is not yet released.
Not sure what you mean with "helper".
Normally you would add the RuuviTags from Settings / I/O / Bluetooth sensors menu.
If the menu does not exist, this could mean the Pi's bluetooth sensor is not working. Then simply add one of these Bluetooth USB dongles.
Sorry to bother you but I purchased a new identical SD card and put on V2.66. All fine I can connect with Venus.local. I then put V2.80 tried v2.85 on the same card. It all seems to boot ok but I can't get in with Venus.local. Any ideas would be appreciated. I have tried balenaEtcher and the RPI imager. Still no response.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
58 People are following this question.
Pi install with 7 inch touch screen, any change of higher resolution now that CANvu is out?
Digital Input for a tank monitor? dbus? Anyone working on it? I've got $100 to start a fund.
Building a Raspberry Pi with Venus OS
Raspberry Pi Venus OS local file system question
Help with Raspberry Pi with Expander Pi (for RTC and tank levels)
