thepilot avatar image
thepilot asked
Does Quattro require DNO with DC PV setup
Hi
Having read throught the ESS manual and design criteria, do I need to inform my grid supplier if I setup the Quattro ESS with a DC side PV array using MPPT and have no loads on the AC In side of the Quattro?
If setup properly with the recommended anti-islanding device I assume the quattro would be disconnected if the grid failed and with no feed in from the MPPT there would be no power fed back to the grid?
@thepilot
https://blog.spiritenergy.co.uk/homeowner/dno-permission
States it depends on size of system. But usually the local provider would still need to be informed, even if it is just a backup system with battery only.
Alexandra answered ·
@thepilot
This is a local regulations type question. Probably is best to either mention where you are or contact a local dealership/supplier.
