Can you parallel up similar size Multiplus and Multiplus 2 devices - single phase ?
Hi Merle,
All units in a parallel or 3 phase system must be the same type and firmware version, this includes same size, system voltage, and feature set.
The type is indicated by the first four digits of the firmware version number. For details, see the “VE.Bus Firmware Numbering System” section in the VE.Bus Firmware versions explained document.
You cannot parallel a Multiplus with a Multiplus-II. Please read this manual for further conditions:
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
7 People are following this question.
