Elimac avatar image
Elimac asked
Use of soft starter with Multiplus and AC Motor
I 'm curious if anyone has had any success (or not too!) in using a Soft Starter on the output of Inverters /input of loads, specially with those loads that have high inrush current.
I have a 2kW water pump motor that really stresses my 2x 3kVA Multipluses parallel setup. The inrush current is too much. But if I could insert a softstarter, for example some a model from this catalogue:
https://www.tme.eu/Document/7343294bf62785612edaf3b14e573997/ATS01-EN.pdf
Maybe I could power the motor with my offgrid solar gear. Which model would be best? Is there any drawbacks I'm missing out?
wkirby avatar image
wkirby answered ·
This would probably work pretty well. I use a VFD for some of my machine tools and even my baby MultiPlus likes it quite a lot.
Elimac avatar image Elimac commented ·
Thanks @WKirby! VFD and Softstarters are different animals... are you implying softstart will also be a good bet? By the way, what is the relationship between the peak current of your load and the peak current of the MP you managed to use?
Kevin Windrem avatar image
Kevin Windrem answered ·
A soft start for your pump should help significantly. The one in your like would require some manual adjustments but should at least help with startup surge.
I have a Multi Compact in my RV and installed a MicroAir soft start unit on the air conditioner. I was able to start the air conditioner on inverter without the soft start but it was a struggle. Now the Multi handles the startup much better. I've also tested this when running the RV on a 2000 VA generator with the Multi bypassed and the air conditioner starts even with ECO on.
I've since installed a similar unit on my home air conditioner and am able to start it on a 5500 VA generator. Before the soft start, the generator would overload and drop the loads.
The MicroAir units are self learning but may be specific to air conditioner/heat pump units. They are designed for capacitor start/run motors. You might check with them about using one on your pump.
Luit Jan avatar image
Luit Jan answered ·
Hi all,
I have tried two different types of Softstarters but both destroyed my 230V net. It was installed after the Quattro 5000.
Does anybody have good experience with a softstarter? I now start the Pump (1,5kW) without and this is giving a dip in the net.
What type of softstarter should be used?
Thanks
Luit Jan
manta avatar image manta commented ·
You can look into a simple NTC softstarter with a bypass relay. Not sure if it will work for your motor but use a Ametherm MS35-20010 NTC for my isolation transformer (5Kva) which was tripping the breaker on startup, now i can startup without tripping a normal 230v 10A shore breaker. After a second there is a timer relay and a (AC3) bypass relay which activates so the NTC can cool and does not create a lot of parasitic load & makes the unit restartable if needed. The NTC stays connected paralell and stay's at ambient temp after cooling. Cheap and simple solution.
