The Jolly Sailor avatar image
3 solid Led Lights on MPPT
Vitron 100/30 MPPT 3 solid Blue led lights on any idea what that means. Thanks.
led
Stanislav Vávra avatar image
When you cant reach it via Gx device or via VictronConnect, there is a problem with MPPT. Has it worked for some time normally? Maybe there went to much current from PV.
Share
Johnsparrow avatar image
Got the same problem here. Connect battery leads and all 3 lights come on and stay on. Anyone know what it means?
Share
Murray van Graan avatar image
According to the Victron toolkit three led’s that stays on means it’s “power-up”
I guess it’s only suppose to do this upon startup, and then commence normal operation. Can you connect to it using VictronConnect?
Share
