My connecting screw clamp no longer tightens at all. I have to jam two wires in there. Is there anyway to fix this problem? The clamp side is stuck wide open. I can not move it with a screw driver. Perhaps the screw is damaged.
It is stuck wide open so it would be over-loosening versus over tightening. It is probably something I can exchange with the vendor but the logistics make that difficult, at least until we are off the boat. I inserted a screw, which solved the problem, perhaps permanently. As the unit now seems to work much better than ever, even when new, I think the problem was there from the beginning. Thanks for the reply.
59 People are following this question.
