hodgson avatar image
hodgson asked
Venus with current sensor stuck in settings
I recently changed customer location of a Venus GX. In the previous installation it had a current sensor connected for PV Inverter consumption. In the new installation the there is no PV Inverter or current sensor but I can't seem to find a way to remove it from the Venus's settings, as such the consumption tab on the dashboard does not work. Is there a way to set a Venus back to factory settings or some other method of removing the current sensor?
Venus GX - VGX
Izak (Victron Energy Staff) avatar image
Izak (Victron Energy Staff) answered ·
There is presently no way to delete such meters, at least none that are user accessible. The only way to remove it is on a very low level: to root the device, stop the localsettings service, and then to edit the settings file on the device (it's an XML file).
https://www.victronenergy.com/live/ccgx:root_access
Warwick Bruce Chapman avatar image Warwick Bruce Chapman commented ·
For those who are also looking, you stop the service with:
svc -d /service/localsettings
Then edit /data/conf/settings.xml and reboot.
You could very easily break something by doing this but I used this approach to remove a PV inverter that did not belong on a site anymore.
