joncrowell avatar image
joncrowell asked
MPPT 100/20 load output ok for DC-AC inverter and DC 24 V Motors (10A max draw)
I need to connect an AC inverter to a system with 400W solar (24V) and 100AH battery (24V) to source some DC pumps (24V, 5A max) and a DC-AC inverter supplying 20W @120V AC..
Can these go to the load output of the controller or do I need an external load dump relay and is there a control from the MPPT 100/20 controller? How to connect? Can i use the Victron Battery Protect 12/24-volt 65AMP?
Thanks,
Jon
solarbattery connection
kevgermany avatar image
kevgermany answered ·
If you connect to load, you can program a load disconnect voltage, means you don't need a battery protect.
