Hi all. I’ve a system with a 24V Multiplus inverter/charger . It has a single AC input, which I have connected to a 230V accessory socket. I can either hook this up to shore (grid) power, or, a diesel genny that we carry about (work vehicle).
My question is, is there a simple way to update the ‘AC Input 1 Type’ on the CerboGX to the actual source type (maybe using the digital inputs? Is that possible?) so that, when looking at reports on VRM, we get accurate data?
I can manually do this via our GX Touch, but it’s like a million menu items to find and the chances are someone will forget to set it correctly. So I was thinking a selector switch would be ideal if it was possible to toggle it in this way.
Thanks!
