joe1234 avatar image
joe1234 asked
Installing two quatro 5000 120 volt in split phase 240 volt off grid and want to wire a 240 volt generator to both Quatros 120 volts each and use both battery chargers to double my charge rate is this possible?
Installing two Quattro 5000 120 volt in split phase 240 volt off grid and want to wire a 240 volt generator to both Quattros 120 volts each and use both battery chargers to double my charge rate is this possible?
snoobler avatar image
snoobler answered ·
Assuming the generator is 120/240VAC split phase, yes.
joe1234 avatar image joe1234 commented ·
Do you know the best place to find a wiring diagram for this. I have been looking through Victrons website and the search function doesn't seem to work like I think. I am struggling to find it.
snoobler answered ·
