A little bit more context would be helpful. That said you may find a cyrix battery combiner or small dc-dc trickle charger may meet your needs. Really depends on what you are trying to achieve,
Thanks for answering,
greetings bram.
in a similar post @kevgermany recommended that Votronic make a trickle charger to keep your starter battery topped up from the auxiliary system and that a second Orion for this is overkill.
It's a low cost option. The Orion setup described by @Trevor Bird below will work, but at higher cost.
Hello @Bram Peeters . If you use an Orion DC-DC charger you can control when it activates by using a BMV 712 or a Smartshunt. You could set a SOC to close a relay and use that relay contact closure to tell the Orion to activate through its remote terminal. The BMV or Smartshunt are programmed via the Bluetooth and the Orion can be interrogated via Bluetooth also. If using the smartshunt it would need to be connected to a CerboGX to get access to relay contacts..
60 People are following this question.
