Dear All,
Can someone have an idea why the Multiplus II stay in float mode even if the required power for the load is higher then the solar power. Normally, battery power must be combined with solar power to absorb the load power.
Best regards
Dear All,
Best regards
By default the Multi will switch out of float when battery voltage drops. Normally it will use AC in before draining the batteries. To change this you need to change the settings in the multi.
I had these problems on a regular basis in the past but not recently.
In my case the PV inverter is on the AC Input of the Multi.
@ kevgermay Where to change the setting in the multi ?
I was waiting this problem to be fixed for several years doing manual Multi restart to get out of that "frozen" state back to normal - thanks to Victron it is possible to do it remotely. I was updating firmware on a regular basis with no change. But after the last update two or three months ago, the problem disappeared. Hopefully forever.
I feel more and more that Victron software is not robust and don't promise what is writen in the manual. Lot of bugs in a not matured soft.
27 People are following this question.
